Got a couple of questions. Was putting the timing back on this weekend and I kept having the same problem each day. I couldn't get the timing marks from the sprockets to the back plate PERFECTLY alined. Still, I managed to get the teeth with the marks at least half touching the line that goes all the way up to the mark on the back plate....
I don't know if that made any sense......... cuz even with the car in front, I couldn't explain it that well for a while to the 40-years of experience mechanic at home until he sat down himself with his glasses and saw it. Anyhow, if no one gets it, I'll take a pic.
Second thing. The spark plug wires on our 7M's are pretty thick compared to MANY other cars, so are they ok to use for about 350whp?
And third, I remember seeing in a thread a few months ago a discussion about copper spark plugs vs platinum. Which one should I go buy tomorrow? And just in case, no, I'm not using any nitrous. Ah, and I'm guessing I should stick with either the stock heat range or 1 level lower right?
