Since I have done the swap not long ago, the tach had never worked. It was an NA originally, but I have put in a turbo tach and have a converter. None of that made the tach work. So now I'm doing what I should have started with, the wiring. Well I have no signal when I jump the tach straight to the ig- on the diagnostic. So I tried jumping a wire from the igniter with no signal again. The care runs great, I just don't know what the problem is? Do I have a wiring issue further before? Or is it not sending the signal? Bad igniter? Or is there another spot I can check or jump to see? I don't know, any help would be appreciated.
thanks
thanks
