If I were to get a 7mgte engine
Chambers
Now you know
Sep 9, 2007
981
Baltimore County, Maryland
There are very minor differences between the turbo auto trans and the non turbo one. The computer is one, the turbo has different parameters built into the box for shift points. Just make sure you buy a Pre-89 (yellow plug) automatic GTE harness. The manual harness/ ECU will not work with the auto box.
Short answer: Yes.
Long answer: Yes, but you probably don't want to as the GTE transmission was beefed up a bit to handle the added power. Why would you want to keep your old transmission?
Dan_Gyoba
Turbo Swapper
Aug 9, 2007
1,836
Alberta
www.gyoba.com
You need dollars to install a 7M-GTE, too. Or time, tools and expertise, which your original question leads me to believe that you don't have. Even then, it's not as cheap as you might think.
