Idle WTF?
Justin
Speakers?
Spokane, Wa
My idle has always been high, ever since i rebuilt my engine 1000 miles ago. Its sat at about 1k RPMs.
I installed my VPC two days ago and nothing changed...
Today I put in new plugs injectors (440s, fresh bag from RC Eng) and now the idle is about 1500. Its pretty damn high!
If I floor it real quick and letup it'll go down a little bit but then come back up...
how can I get my idle to where the hell its supposed to be???
Justin
Speakers?
Spokane, Wa
Also, I've just recently noticed that the idle will flucuate... it'll go from 950-1040 very steady like...
any input on what could cause that? I didn't see anything in the TSRM about that....
8,897
Start by checking DTC's. You probably have a fault in the idle air control circuit.
edit: look for a vaccum leak also
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
hey i got an easy way to fix it ajust you thottle plate stop screw
in less you isc is gumbed up and slow reacting
any wyas have fun
Justin
Speakers?
Spokane, Wa
I'm sorry, DTC's?
I replaced my ISC with another unit I had laying around that I cleaned up very well... When I first installed it idle seemed to be around 800 which was better but not ideal.
After It set for a few hours and I came home the idle was up high again....
I guess FPR and TPS are next.
Racefiend
OH, YEAAHH!
Apr 6, 2005
106
Bay Area, CA
Check the isc operation by tsrm, same with tps, and fpr like you say. If all checks ok and you have no vacuum leaks, then adjust your idle screw.
