idle speed control ?
blacksupra
291
Buena Park,CA
I tried this before to check if my isc was ok. I unplugged the isc and the rpms went up at 1,500 to 2000 rpms but when i put it back on the idle went down to 650 rpms. Yesterday I checked it and it didn't do anything. I unplugged the isc and started the car and nothing happened. I can heard the 3 clicks though. Any idea please.
supraman7mgte
Shut up,bitch!!
Sunny California
i had a similar problem with my isc,sometimes it would work,and other times it would just idle at about 650 rpm's or die. I took off the isc and cleaned out alot of carbon build-up and tested it via some instructions I found on this site. Now it runs with no problems. If you can find a spare at your local junk yard,i'd take it. The isc for the 7mge and the 7mgte are the same.
