idle setting
mk3-4-me
669
Milwaukee, WI
so i had no idle screw on my throtte body. I found a hole for a screw on the throttle pulley thing where the throttle cable hooks up. I have it where the screw pushes down on on a springy air valve thing.
does this sound right? i know not the best description... lol
where r your idle screws?
SRY I DNT GOT ANY PICS TO HELP MY IPHONE BROKE!! WAITING TO GET THE NEW ONE.
mkiiichip
1,434
WI
Idle is set by the computer with the ISCV. If the idle is out of spec you have an issue, that turning a screw is not going to fix.
What is the problem?
mk3-4-me
669
Milwaukee, WI
well i havnt started my motor after i rebuilt it yet, and i dont have the screw. Isn't there supposed to be a screw that controls how much the butterfly door thing inside the throttle body stays open. Like so its not completely closed when im not on the throttle.
giterboosted
cure for the common rice
Nov 3, 2007
597
toccoa ga
From what I've gathered out of your description yes that's where it goes, I'll try to take a pic soon for you, and wether it's the "correct" way or not, yes you cam adjust your idle with it, I don't believe it has to be a specific screw as lon as it fits in the threads, I can't recall which direction does what but I hope that helped!!
supraguy@aol
Well-Known Member
Dec 30, 2005
4,239
Atlanta
I think that screw, which strikes the dashpot piston, is just for helping to normalize the rpm dropoff when closing the throttle quickly. I don't think it adjusts idle at all.
