First I want to say I have no codes thrown. I replaced the AFM, engine harness, throttle body, TPS, ISC, Igniter, CPS, plugs and wires over a period of 6 months. I have the 550/Lexus mod with S-AFC Neo, ARP studs, HKS MHG.
Timing has been set correctly.
The car starts and runs fine at first but starts to stumble and miss as it approaches operating temperature. It revs fine in the higher RPM range (1,500 to 6,000) but when you decelerate and hit around 1,000 RPM it wants to stall. If you quickly accelerate and let go then it will reach around 1,000 and always stall out.
I checked the vacuum lines and found nothing loose. Vacuum is between -18 and -20 when idling.
I guess I can go around with a multimeter and check all the electronics. This car has never really idled correctly, even before all my mods 8 years ago. It always had the miss.
Update: I just used another ECU and the car seems to be a bit better - not as much stalling. However, it still has a miss at idle and fluctuates between 700 and 900 RPMs when idling.
