Idle problem
oheylnaishca
12
Texas
Ok here is my problem. I did my timing on my 7mgte as you can see the video was taken on the first start up. My problem is:
1. The car wont idle. It started good and it started dying.
2. I started the car back up again and it didnt even idle it just went to1000 rpm then it dies down.
3. I need help on what kind of AN fitting or does any know where I can find a steelbraided line for a t4 turbo cause mine are leaking after I upgraded my turbo.
4. And yes the TB is fully closed before start up. I did the whole resistance test (=
Any help would be appreciated.
[video=youtube;80EKTqeVWAY]http://www.youtube.com/watch?v=80EKTqeVWAY[/video]
StrikeIS
61
Va
check cps. if its out by a lot it will still start but will just shut off. may be a vac leak also. not much info was given.
oheylnaishca
12
Texas
no codes so far waiting on new lines for the turbo will start it asap. I think the CPS was not on the right position so I Re-did everything. Will post a new step-by-step on what I did with pictures.
Northbaysupra
BAY AREA MKIII
Mar 19, 2010
135
Petaluma
I had the same problem . Found out i had a bad injector. Test every things with an ohms tester ,. according to tsrm.To help found your problem
---------- Post added at 02:49 AM ---------- Previous post was at 02:48 AM ----------
do you have 550 cc injectors
