I have a wierd idle issue, cold start i idle at about 1500 witch is fine, once it warms up it idles at about 900-1000rpm sometimes it will idle at 650-800. it never wants to make up its mind, sometimes after i put it into netural the car will want to die the idle hits like 200rpm and will climb back up to 1000, the car has stalled this way and does once and a while. ive heard cleaning out the ISC valve can fix this problem, ive ordered in a new gasket for the ISC. now my question is, cleaning the valve itself, ive noticed it has a black back on it that screws in with 3 or 4 screws, now is removing the back Black cover required to properly clean the valve? or is taking the black cover off a bad idea ? i would love some help. thanks in advance guys.
