Mkay, long story short, my idle is all sorts of fucked up.
<running generally rough, but yeah>
for the past long time, its been idling really rough, at somewhere around 1500 RPMs
<cant tell you for certain, since my tach hasnt worked at all since I did the GTE swap>
anyway, we were fucking around with it last night, and realized that the ISC was loose...
so we tighten it up a bit, and voila, the idle smooths out.
<still high, but pretty damn smooth>
said smooth idle only lasted a couple minutes, then back to rough, the engine even almost died a couple times.
fire her up a couple hours later, same deal, starts out smooth, then after 20 seconds or so, gets rough....
pretty much narrowed it down to TPS, ISC, Vacuum, or fouled plugs...
so yeah, my questions would be... ideas?
also, the TSRM says that after you shut down the engine, the ISC should make a ticking noise... but mine doesnt seem to...
how loud is that noise supposed to be? is it possible that my terrible ears just missed it?
phew.
Cliffs: Car idles high, starts smooth, then quickly gets really rough. ISC is/was loose.
thanks in advance.
phew.
thanks in advance.
