Idle Drop/Stall with A/C on????
Canyon Racer
9
Death Valley Cali
Okay, I've combed the forums and the TSRM. Which of you Supra techies can tell me what's wrong...when I turn on the a/c, the idle doesn't go up. It drops to around 500, and sometimes almost stalls. Sensor? Wire? Relay? Where do I look? Thanks!
86.5 MKIII, 7M-GE, 5-Speed
amichie
182
sYDNEy
Have you cleaned out the ISCV? It may just be blocked and can't let more air in for idle up. Does it idle up when you turn the steering wheel at idle?
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
It's much more likely that the ECU isn't getting a signal when the A/C is on... and as such isn't idling up.
Check the wiring that runs to the compressor. Then look at the third to the last tech tip here: http://www.cygnusx1.net/Supra/Library/TEWD/MK3/manual.aspx?S=Main&P=58 for info on how to test when/if the TCCS is getting a signal when the A/C is on or off.
Always post any codes you find whether you think they're vague or not.... saves more time than you might imagine.
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Do it the easy way first:
1) No 51 with the AC off and throttle closed.
2) 51 with the AC off and throttle cracked.
3) 51 with the AC on and throttle closed.
Anything else, do what you suggested. Clutch activation without idle up is usually caused by a bad AC amplifier. Course there could be a wiring problem in that area too.
Fwiw AC idle up is not as simple as other idle ups in that for AC the ECU advances timing in order to "get a jump" on idle speed. It's why turning the AC on causes an immediate increase in idle, before it drops. If it was just a matter of manipulating the ISCV it would drop first the way it does with headlights and defog operation. Bet ya didn't know that did ya? ;)
