Idle, 750 in Drive, 1000 in park and neutral
Gunnar
116
Belgium
www.chiptuners.org
Just cleaning up some small bugs after the rebuild.
It idles fine when in drive and the brake pedal is pressed, however when put in Neutral or Park it idles at 1000 rpm, which makes it a bit jerky when you go form there to drive to pull away.
Anyone know if im missing a switch or wire somewhere?
