IC piping
Steely
123
Rhode Island
anyone got more info on this setup.... its definitely different
tbcmorris
SM Expert Thread Derailer
Mar 14, 2007
1,820
PRUVEN PERFORMANCE MILFORD CT
benchwarmer;1252172 said:
Ah yes, Hommersimpson is his Username on here. A search of his posts will turn up his explanation of that....uh.....thing.
Yes and do make sure you check out the awesome "custom" dashboard.
Sorry if I come off like a dick I'm not...but damn he destroyed that car
SC Rydah
86
New Jersey
I feel bad for him whenever he has to change those plugs!! That hot pipe running over the wires AND the upper radiator hose CANNOT be good. I guess he gets less lag that way though. But the "sleeper look" goes out the window with the hood he had to put on it to clear the pipes.
benchwarmer
Straight Cougar
Aug 2, 2007
510
Lancaster, CA
Looks like he took all the pictures down of his piping setup, even his photobucket. As odd as that setup is I must admit it's pretty cool looking.
Steely
123
Rhode Island
thats exactly what i was thinking.... i like when people get creative with the IC piping with the stock intake manifold. gotta give props for original
jdub
Feb 10, 2006
10,730
Valley of the Sun
Not when it's routed in a manner that exposes it to the max heat possible and requires you to hack your hood for it to fit ;)
Canuckrz
852
Calgary, Alberta
Yeah he took it all down because too many people were bashing him iirc, its a pity because even though it was a bit outlandish he was at least thinking outside the box so it was interesting.
92nsx
2,957
Clearwater, MN
How "hot" do you think the IC piping gets? :nono:
It dosent get that hot where you would need to worry about it. The only problem would be the piping getting heat soaked
