Alright heres the deal guys, I just got a new 7M-GE put in, with my electronics and what not. On the last engine the TPS and AFM went out for me and I put in new ones from diffrent cars. The problem I have is that my damn RPMs will jump from like 3000 to 5000! for no reason. I give it gas and not only do the RPMs jump but the tranny sometimes will shift at higher RPMs then usual. For instance I'll be driveing and when I give it gas it accelerates diffrently each time. When it would normally shift from 1st to 2nd at 2000 it will shift from 1st to 2nd at like nearly 3500! Then from like 2nd to 3rd at almost 4500!
I know the TPS has to be the cause because I run the codes and get 41 which is the TPS. Should I just try and adjust it? I have no idea what it position on the TB it should be set nor if the problem is the fact that the TPS is off a diffrent car. I need some seriouse help here guys because I dont want to drive it if this will eventually give me a BHG or something until I get it fixed.
I plan to take it to a shop I know very well, and have them take a look and see if they can help.
