ok so recently i have started to see a lot od smoke comming out the supra, most likely it is my turbo seals, but i am going to do a compression test later, i have a friend that told me to check my pcv system, because he said that he had a pcv system valve go bad, and his car started to smoke a lot, but do we have a pcv valve or anything like that, that might also cause it to smoke badly? If it is my turbo seals, how much should i be looking to spend to have it rebuilt, and with a trim? well please and thanks ricardo
