I screwed up.... please help
black91turbo
Formerly black87turbo
Apr 27, 2006
1,064
Jacksonville, FL
I stripped a damn head bolt....... the second one from the front on the intake side..... The rest of the bolts came out without a problem. I am so pissed at myself right now :rant: Any ideas on how to take it out???
Thanks guys
MDCmotorsports
Indy 500
www.MDCmotorsports.com
willfish said:
drill it out
Will
About your only option if its completely stripped.
Also, make sure if you are drilling:
-Drill slow
-Use lots of oil on the drill bit
-Wear safety glasses
-Use a carbide or other hard material drill (HS steel just won't do the job)
black91turbo
Apr 27, 2006
1,064
Jacksonville, FL
Where the hell do you get a sock-it-out tool?? i just did some searching and some guy got it loose with one of those...hmmmmmm Yeah, I am pretty sure i will kill my head if I drill. :icon_conf
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
before you do any drilling.
First thing you do is clean the head with some carb cleaner or such. get all the goo and oil crap from the bolt head. Then take the hex socket and tap it in with the hammer all the way. make sure it goes in all the way and not just stops somewhere ( this is where the cleaning is important. )
Try opening the bolt after its all the way in.
It happened to me once, and after struggling and panicking, I cleaned the bolt head and eventhough the top are was stripped, when I knocked the socket in all the way ...it opened up.
Moe
black91turbo
Apr 27, 2006
1,064
Jacksonville, FL
thanks bud!!! ..... I will give it a try tommorow morning....
The motor is out of the car by the way, so maybe that will make it a little easier.
phoenix6
Rockin' the blades
Aug 13, 2006
1,138
Serena's Place ;)
another (*not suggested unless needed*) option would be to use some JB Weld, toss the hex head in there, hammer it in a bit with some JB weld around it, and let it sit overnight
next afternoon, should come out
suprastanger507mgte
Hayward , Ca
That is the next best option to avoid drilling.
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
A last option would be to put int the hex key and weld it on there if you have access to one. You'll be getting a new head bolt anyway. Just make sure to put something around the bolt because of the sparks
themadhatter
760
Vegas
you beat me to it. ya just tack weld the key on to the bolt
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
see if you can find something called "strip out", our local hardware store sells it and its just a gritty paste in a tube :) works like a charm, its saved my ass a few times from stripped bolts (just put some in the head of the bolt or around the socket/hex key and it should lock it up enough to let you turn.
ive also heard that valve lapping compound works the same way.
7Mboost
7M Powered
Aug 15, 2006
2,201
Gainesville, FL
I would let a professional do any drilling and extracting if it comes to that, they have the quality tools and skill today not to say you don't but if you can't get it out your fucked.
black91turbo
Apr 27, 2006
1,064
Jacksonville, FL
I got the bitch out today......... :icon_bigg Just took a longer hex (one of the ones with a handle) and broke it loose. It seems that when I initially started messing with it the hex bit I was using was too damn short to get all the way to the bottom of that damn stock bolt. Anyhow, as long as the story has a happy ending I guess. I am sure this won't be the last thing I screw up as I am building thing :biglaugh:
suprastanger507mgte
Hayward , Ca
Ususally that is the case as I found out when I had the problem. I was able to knock it down and into place.
Good job man. Its always good when things aren't really as bad as it looks.
Clip
Oct 16, 2005
2,738
9
Virginia
congrats! and don't sweat it, everything is fixable.
