I had been fighting with getting my TPS set correctly for the past few days and last night I bought an analog multimeter and finally got it dialed in.
I first set the throttle stop screw so that the throttle gap was 0.0015'', I then slowly rotated the TPS until it deflected and tightened it down. I checked the TPS per the TSRM and all the specs checked out. I then disconnected the battery and pulled the ECU fuse for 30 seconds.
Now the trouble...I started the car and it was idling high...around 1500 rpm. I let the car warm up and the idle did not come back down. During a moment of poor judgment I grabbed a screw driver and started to turn the idle screw on the throttle body...the idle started to come down but the screw bottomed out before the idle got to where I wanted...only got down to 1000 rpm.
Frustrated...I stopped for the night. Got online and started searching the forums about high idle and adjusting idle etc etc and to my horror nearly every thread said DO NOT ADJUST THE IDLE SCREW ON THE THROTTLE BODY.
So I search through the TSRM but could not find anything about adjusting the idle screw or what it should be set to.
So my question is...does anyone know where the idle screw should be set to? Preferably how many counterclockwise turns from fully closed should it be?
Through my searching I discovered that I should first check the ISC valve and search for vacuum leaks to try to address the high idle issue...not use the idle screw
Thanks for any and all input!!
