i need chassis harness pinouts!! 87 and 90
jbirdmk3
Sarasota FL
i have to basically splice them together i have a 87 engine and i 90 shell i have everything for both but my 90 chassis is in better condition so im doing a nightmare swap i wish it wasnt but i need help withthe wiring for the 90 chassis harness to the 87 engine harness
Chambers
Now you know
Sep 9, 2007
983
Baltimore County, Maryland
So you have a 87 Turbo engine, harness, ECU, etc. and a 90 shell. Is the 90 a turbo car? Is the 90 a auto or manual? Is the 87 ECU/harness auto or manual? This will be quite a under taking, there are many differences between a 87 and 90.
I have all the wiring info for the 87, the 90 is available, Google TSRM, you can get that info online.
If your not hell bent on doing this I'm suggesting you find your self a 90 harness, ECU, etc. and put those onto the 87 engine, that will eliminate many headaches you don't need to have. There are far to many things to be concerned over with these cars and dodgy engine wiring is not one you should.
Good luck.
