I`m stumped
Toyota h8r
Formerly KILLERMK3
Jan 24, 2006
187
Sylvania ohio
I haue been stumped very early in my supra ownership. The problem is that the car wont run w/o jumping the fp in the diag block under the hood. I have tested and replaced the EFI main relay, fp relay, fp resistor, all the fuses. I dont understand if i`m jumping the fp and the car runs, what could be wrong? Thanx for help in advance:)
Topher E
Trance Head
Aug 4, 2005
388
Vacaville
From what i could gather from that it sounds like you have a shrot in the fuel pump wire from the ign to maby the ecm? But it sounds llike your not getting a signal from the ign to the fuel pump saying the car is on.
Have you tried cycling the fp? if not try it.
Toyota h8r
Formerly KILLERMK3
Jan 24, 2006
187
Sylvania ohio
The car is a 87 n/a 5 speed, so to answer some questions. It is a ge and no codes. If someone could help me what is cycling the fuel pump? Thanx to all fellow supra owners that are help get a supra on the road:-D
