I have alot of oil all over the spark plug..
jaime302
23
Elgin IL
I replaced the valve cover gasket allready... can it be be the spark plug tube seal.. its not the valve stem seal.. it dosen't smoke after i turn it on.. any help and if its the SPTS any one know witch one to use?
It's the 4 14mm Allen bolts inbetween the spark plugs. The ones on top.
You can try either a bunch of fipg or what worked better for me was using big oil drain plug gaskets from napa and remove the black piece for the spark plug wires.
