I got Engine Issues
Sonex2000
172
Ok I took to a shop on a friend's refferal
The mechanic tells me it's the rod bearings.
Suggestions?.......I'm open to them.
N
NDBoost
Guest
What do you mean.. suggestions for what?
We can rebuild him, make him bigger, better, stronger, faster
N
NDBoost
Guest
Min repairs: Pull the motor pull the oil pan off and replace the rod bearings.
Max repairs total rebuild from top to bottom.
You COULD do a repair for $100 just not recommended..
7M-GTE
ROCK$T@R
Apr 2, 2005
535
KC
Sonex2000 said:
where do I go from here?
What am I looking at in repairs?
well it sounds like rod bearings... I'd probably turn the crank before reusing it...
N
NDBoost
Guest
spend $100 and risk it throwing a rod or getting Rod knock again.
Or spend $3k do it right and do it once.
7M-GTE
ROCK$T@R
Apr 2, 2005
535
KC
no I agree I wasn't disagreeing with him... I was just saying it's cheaper to do it yourself and that way your garaunteed... just follow toyota specs and you'll be fine... w/ the exception of a mhg and arps...
N
NDBoost
Guest
i wasnt saying you were disagreeing $3k to rebuild a motor with performance parts and have it hold up to anything you throw at it.
Sonex2000
172
Well, the mechanic gave me 2 suggestions.
let hime do the work. = $3000
OR,
Buy another engine that has the work done w/ a 3year warranty. = $2400
N
NDBoost
Guest
For $3k you can have an entire motor built. New rings new gaskets seals, bearings everything..
lagged
1991 1JZ
new rochelle
Sonex2000 said:
whiteplains
i have a rebuilt shortblock for sale, use your head or buy another rebuilt head that i have aswell.
and like i stated earlier i can have your motor rebuilt for cheaper than the price you were quoted for.
Shytheed Dumas
For Sale
Mar 6, 2006
967
Louisville, KY
Lagged - I might be interested in your rebuilt short block if Sonex isn't interested. What are you asking? I'm considering rebuilding mine while the head's off, but I could change my mind if the price is right.
