I deserve the Hall of Shame....Code 24
Who
Like the title says. I buffaloed myself big time today and deserve a swift kick in the ass. I fabbed up a ghetto heat shield and I pulled my Apexi intake out of storage and preceded to remove the stock CAI. No big deal a junior member could perform this task with one hand tied behind his / her back. After I completed the installation the engine ran rough. The idle was surging, dropping and coughing. I checked all the clamps, hoses, AFM plug and everything was on and tight.
Jiggled the AFM plug...No change.
I pulled codes. No codes (Fast blinking light).
I disconnected the AFM plug. Now the idle corrects itself but when you step on the gas the engine shuts down. I Check codes again and now I get code 24 (Intake air Temp Sensor Signal). I figure the plug is good and the afm is working or I wouldn't get a code.
I plug the AFM plug back in and clear the codes.
I Start the engine again and it runs rough, coughing, sputtering same as before. I pull codes again. .... Fast blinking engine light... NO CODES!!! WTF I say to myself.
I pause because I can feel the hair standing up on the back of my neck. Now my nose starts telling me that the exhaust and garage smells like someone has poured gas all over the floor. Personally I hate the smell of gas it makes my stomach turn. So I tell myself. No codes, I got spark, I got fuel, what about AIR, O2 (oxygen).......
Need I say more......Bubble wrap inside the Apexi filter.......Let the flaming begin.
mirage83
457
Georgia
Now THAT is classic! I'm talking a Jon Stewart moment of zen classic.
If only I'd been there to see it. Don't suppose you had anyone filming it for posterity did you? :biglaugh:
SupaMan
Want The Boooooossttttttt
Oct 12, 2006
1,101
Cape Coral,Florida
lol it happens atleast you admitted it.
i did a compression test on my car got it all back together went to start it started up idled fine for 5 or so seconds then started idling like crap wouldnt rev would just die. after 3-4 times of this my friend goes "is everything plugged in" i was like "yea as far as i know" i walk over to the MAF and the plug is hanging there next to it........oops :)
jdub
Feb 10, 2006
10,730
Valley of the Sun
LOL...Might have had a bit of a restriction there huh? :D
Trust me...done more stupid tricks than that. ;)
supramk3speed
305
Texas
That is hilarious! Cool that you admitted that, i did the same thing that supaman did when i replaced my turbo. Felt like a tard.
Mk3runner
2,033
Nor Cal
Almost did the same, put a cone filter on instead of plastic crap. Went for a drive and couldn't figure out why it ran horrible. Popped hood on left upper ic pipe completely off.
Woot for me.. Good show man
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,778
13
Long Island, Ny
happened to a friend of mine, had the engine rebuilt by a shop and when he got the car back it was low on power and ran crappy. like it was hitting fuel cut but at less then stock boost and about 3000 rpm.
turns out the shop put a rag in the turbo so nothing would fall into it and when they put it back together forgot to take it out.
lewis15498
Don't blame ebay cheapass
Sep 28, 2008
1,397
Raynham, Massachusetts, United States
We all fuck up like that sometimes. But props on having the balls to make a thread about it! You have no reason to be embarrased about shit like that unless you cant figure it out and someone else does. How relieved were you when you found the bubble wrap?
