i cant believe how much our seats weigh
catback
bitterville
it feels like it's 60lbs or something :aigo:
new ones are like 12lbs - bracket:evil2:
still need to be bolted down
Dirgle
Conjurer of Boost
Pauma Valley, CA
You do realize its full size for a reason don't you? If both tires are not the same size on the rear you could damage the LSD (assuming you have a differential with the Limited Slip option). A donut spare may work for the front but it won't work for the rear.
stratoayu
435
surrey
i thought the driver in leather was more for some reason... on a side note. i removed 105 lbs from removing my a/c, p/s, and cruise control :|
bowtiebuba
stangs hate supras
Sep 1, 2005
207
marion iowa
damn reading this makes me want to take out my ps a/c and cruise and seats idk i still want my supra to have all that nice stuff
Ckanderson
2,644
The beach
uh yea... stock seats ... uber comfortible... would i replce em? only with reccaro seats of the same or higher confort level
Jeff Lange
Administrator
4,919
5
Sunnyvale, CA
jefflange.ca
Solution:
1. Get flat tire.
2. Get angry.
3. Get donut out of trunk, put on front of vehicle.
4. Put tire from front of vehicle on rear of vehicle.
5. Put flat in trunk.
Or, keep the full size spare, that's what I'm doing, lol.
Dirgle
Conjurer of Boost
Pauma Valley, CA
LOL, good point Jeff. I didn't even think of the musical tires approach. I just consider it a luxury to finally have a car that has a full size spare. I hate donut spares with a passion.
I guess your idea would work as long as the person understands that your not supposed to put a donut on the back.
Unless you have two donut spares……then you just getting cheap.
catback
bitterville
i removed the spare all-together( can of fix a flat)+
potenza run flats all the way around
no ac
no cruise
the stock seats are really really awesome but since i dont use my car as a DD anymore, i thought why not.
i only put 800kms on the ODO this year:naughty: :biglaugh: :nono:
87centertips
107
edmonton alberta
they also give u the full size spare because the stock saw blades are made to push air in to ur braks to cool them down to alow better performance driving longer thats why the tires are also marked with a (L)and(R)
:biglaugh: see u learn somthing every day
lanternman
153
MI
The tires are marked with an R and L because they have directional tread. The Sawblades were designed to go on a certain way, but it was also to ensure you don't have a tire on backwards. I don't see how a full sized spare affects that.
catback
bitterville
" but it is true that the rims are made to cool ur brakes."
no more than most other wheels:icon_bigg
PS. they're called wheels:naughty:
D34DC311
i dont think i'll remove the PS (not in the near future anyways)
now i need the harness bar that goes across the back for the 5 pt harnesses
and sliders
going to go to the wreckers next week and see if can rape a GE with no power seats unless theres a better way.
any input? anybody?
dbsupra90
toonar
indiucky
it is true you dont want 2 diff size tires in the rear. however, you have to keep in mind our spare is stock height. if you are running diff size rims and tires, say a 275/40/17 you will have the same problem. stock tire height is 24.85 while a 275/40 is 25.66. also keep in mind donut tires are the same height as a full size, just not as wide. that being said, donut or full size you have to pay attention to the height, not the width.
