Hydrofan Set with ECU needed
Satan
Tampa
I have the fan, ecu, and pump/reservoir/cooler.... ~$150 plus shipping.
The shroud is included, but has been cut/trimmed, but you can fit it and put it back together.
Satan
Tampa
Sorry... may have to wait for pics 'til the weekend... Gotta few things goin' on and need to pull all them boxes out and sort thru...
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
haha ok no problem engine wont be coming in until next week anyways....thanks man how bad is the fan shroud trimmed up?? just a little bit on the drivers side due to 3 inch piping or something?
Satan
Tampa
I cut it form each of the sides, about a couple of inches, in a straight vertical line. Basically was going to narrow the shroud to fit on the 7M auto radiator. The Aristo radiator was too wide for the MKIII frame. I was going to trim these pieces of the shroud and then join back tohether and use some sealant on the seam, so that it would only ally the air to be move where the fan makes it.
But I ended up putting a USDM 2J waterpump on, so I didn't need to modify further.
The Reaper
Jan 10, 2006
1,909
Florida
so it still mounts perfectly fine with no problems? im gonna put it on a 5spd 7M radiator if there is a difference....
let me know i need to get this from you ASAP
Satan
Tampa
I'll see what I can do to pull everything out and take pics tonight (but no promises).
Do you need the wiring/plug to the ECU or anything else? I'll have to see what I can find. Hopefully you have those connectors, etc, on your harness already.
The Reaper
Jan 10, 2006
1,909
Florida
yea the harness is uncut so im sure it does have them
yea cause i'd like to get this stuff ASAP so i can get the car up n running sooner
