huge loss of power
cartel1_950
supra is gone
Jan 30, 2006
498
calgary
hey there guys i got a 92 turbo, completly stock, i have had the headgasket replaced already. but recently i've had no power. started little. now no power at all. could it be my clutch or a vacum leak or something worse. i'm not blowing any smoke and it idles just like normal. any ideas??
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Have you checked for codes?
Clutch is easy to check. In 5th gear on the highway, at about 1500rpm, accelerate as hard as you can. As the speed increases, keep an eye on the RPM - if it jumps up suddenly without a similar increase in speed, your clutch is fried.
Could also be a boost leak - have any of your intercooler pipes been replaced since the car was new? If not, chances are you have a bunch of leaks.
cartel1_950
supra is gone
Jan 30, 2006
498
calgary
the car is red. just been power polished and detailed so it's nice and shiny. and does it sound like it could be a engine problem. at 3k rpm if you try to accelerate it doesn't do anything no raised rpms or speed or anything
p5150
ASE and FAA A&P Certified
Central Idaho
sounds like a clogged catalytic converter to me
Buy a downpipe and exhaust - I bet your problem will go away
