How to tell a JDM Engine???
TurboWeenie
7M-GTblownheadgasketE
Jul 22, 2007
32
KS
I recently pulled the engine out of my car and am wondering if its a JDM or not. The metal coolant pipe that runs along the exhaust side of the block that goes to the heater core on the driver's side looks like it has been factory capped off. The previous owner had a hose running over the head to the heater core from the passenger's side outlet of the pipe. Also, the car is a 1990, but the engine has a 6m crank. Is there a sure way to tell if the engine is indeed a JDM replacement?
Thanks
-Ryan
TurboWarrior
Canada
When a jdm motors are installed the usdm mani, egr etc is swapped over from your old motor. So thats not a way to tell
lagged
1991 1JZ
new rochelle
you mean, the when the JDM motor is installed its possible the installer swapped over the EGR components in order to pass emissions. right?
TurboWarrior
Canada
right. Ive owned 2 supras. Both with jdm motors installed at one point. Both had the egr system and usdm mani. I suppose lazier mechanics would forego installing the egr. Unless there is no need to keep the car legal. I have the jdm mani in a box the last owner kept from my supra now.
