How to retain aircon with short runner FFIM
May 18, 2007
704
Aarhus
I'd like to start a thread with possible ways of retaining a/c on a 7MGTE with a short runner FFIM.
As far as I can see the problem is that there will not be enough space to drop the alternator low enough when using a short runner.
So I was thinking in the lines of an electrical a/c pump or an electrical power steering pump. I have been told the MR2 uses an electrical power steering pump.
Has anyone been thinking along these lines?
tubbie
Yes, powerful Jedi....
Apr 4, 2005
821
Hoschton, GA
FFIM without moving anything....
VaamRwg&
May 18, 2007
704
Aarhus
Someone at SF told me that the Toyota Prius uses an electrical a/c pump.
I'll do some more research on that one.
Apparently it uses 150V. But I'll have to look into that.
May 18, 2007
704
Aarhus
Maybe it could be mounted in front of the a/c pump instead (keeping the a/c in stock posistion), so the alternator is driven from the backside?
May 18, 2007
704
Aarhus
I been measuring on the car and I'm not so sure the a/c pump will not fit behind the alternator.
It needs to clear the steering column (lhd) but I think it might work.
The alternator just needs two pullies (on in each end) and a small belt for the a/c pump which could be raised above and behind the alternator.
The problem might be to find an alternator of sufficient amps.
