I cannot find any tool to reach in between the firewall and back of the head to get the hose clips off of water bypass hose #5. Anyone have any tips for doing this one?
PorterzSupra said:clip it with tin snips and or twist and pull till the clip breaks. Mine I was able to use the swivel arm and socket to loosen it
GrimJack said:I have a different method.
I pull the hose from the top - the one that goes to the firewall for the heater. Then put a BIG socket on the fitting that hose runs too and pull the whole fitting off. It's easy to get the hose off when you have the hose & fitting on your bench instead of on the car.
