How to remove water pump housing?
Datsrboi
Loud pipes Save Lives
Jul 31, 2007
797
Haltom Texas
I look through all the TSRM and search my eye balls off online and no luck. I got the water pump off the supra but how in the world do I remove the water pump housing? Its a bit dark to try right now but It would be better to see one done before I attempt.
Please :(
mkIIIman089
Ohio
IIRC it's one big piece and part of the timing cover.
You need to take all the timing stuff off the front of the motor, then it will come off. I've never done it but you might want to see how the oil pan seals up as well, just to be sure you can get it back on without creating a huge leak.
Datsrboi
Jul 31, 2007
797
Haltom Texas
Holy Sh1t what have I gotten myself into with this car...... :sarcasm: :icon_mad:
bowsercake
828
Irvine, Ca
To remove the water pump you need to remove the fan. The fan clutch is attached to the waterpump and could come out with it but when I think that it might be easier to remove it first. There are a bunch of little bolts (and a few nuts) holding it into place.
You DO NOT have to remove the engine timing cover to get to it.
Water Pump alone:
http://www.cygnusx1.net/Supra/Library/EPC/291420/catalog.aspx?F=1601&P=1
Timing cover and water pump shown:
http://www.cygnusx1.net/Supra/Library/EPC/291420/catalog.aspx?F=1106&P=1
ahhhh
damn, both of mine look like the front cover is actually coated where the waterpump is.
current engine was one that had only water run through it (it ate the head, had to rebuild my old head). Pulled the waterpump at it looks pretty bad, but the waterpump housing was dark grey like my other one in there and there wasn't any sign of erosion...
But like others have said, it's NOT a simple thing to remove, it pretty much requires full disassembly of the engine...
mkIIIman089
Ohio
^ It's not bad enough to just cop out like that. If you have changed the timing belt you're more then half way there.
