charcoal canister is only held on by 10 or 12 mm bolts, run a vaccum line off the hard line on the fire wall through the grommet where the dump at the bottom of the charcoal canister use to sit, you'll see it. and other egr stuff is hard to get off unless you take the intake manifold off(upper half) the egr has 2 12mm bolts holding it on and 2 12 mm bolts on the upper part of the intake manifold, you need block off plates and start eliminating vaccum lines and the vsv crap underneath the manifold as well
