how to make 2jz two way system to parallel
nissansupra
13
songkhla
Hi SM,
I believe the title is clear enough for expert to reply this thread. According to your experiences and knowledge, it is doable? This tweak crossing my mind since i got a few problem with two way setup is it any tips on how to change the system into parallel like 1jz? the second turbo is not working as it suppose to. Appreciate if you could share with all of SM members and me.
thank you in advance
OneJArpus;1634242 said:
look in the MKIV section or SF i'm sure its been done tons of times
This^^ it's supraforums.com if you're not familiar.
Also, it increases lag quite a bit, I'd be looking at fixing the sequential system personally..
nissansupra
13
songkhla
thank you guys.... =), actually when i browse to MKIV section i only can see two thread which are rules and regulation and tech post =(
mattsplat72
is sofa king
Jan 17, 2006
1,738
What they are saying is that you should check a different forum. Supraforums.com has a larger MK4 crowd then Supramania. You should be able to find the info easier there because of the large numbers of 2jzgte owners. The majority of owners here have 7mgte's
