How to know you have a Rod Knock?
Status
Not open for further replies.
Turbo Habanero
4,229
Tucson,AZ
IJ.;1401474 said:
It won't smoke and it will knock when it's running ;)
how much when it was at idle it made a tap noise hoping it was just the lifters or something idk maybe ill go take a vid of the noise. Let you guys decide if its a real problem or me just being over cautious.
Turbo Habanero
4,229
Tucson,AZ
IJ.;1401485 said:
Has your idle oil pressure decreased?
Try pulling an injector clip at a time with it idling and see if the tap changes, replace clip and repeat down the engine.
i went and took a video uploading it know should be up in a min. My oil pressure has not changed according to the stock gauge. It didnt seem to be knocking as loud now
Turbo Habanero
4,229
Tucson,AZ
lewis15498;1401487 said:
If you determine you have a rod knock, stop using the car. He will only knock on the door so long before he decides to kick it in.
True i wouldnt drive it like this im not totally stupid :(
JDMMA70
2,550
Houston
Valve tick and Rod Knock are different. The video in the Exhaust Help/Opinion thread shows my car with valve tick (still havent gotten around to checking the clearances and reshimming).
lewis15498
Don't blame ebay cheapass
Sep 28, 2008
1,397
Raynham, Massachusetts, United States
Wasnt implying that you were stupid. When i was 18 my accord had a bad rod knock. I Just tried to reposition off the grass and onto my driveway to pull the motor. Next thing I know, i'm picking pieces of my block off the driveway. Luckily I wasnt planning on using the motor. My point is things like that can change rapidly.
JDMMA70
2,550
Houston
that honestly sounds like its coming from the top end (aka the Head) cant really much over that fan.
Turbo Habanero
4,229
Tucson,AZ
I see what your saying :)
Turbo Habanero
4,229
Tucson,AZ
The motor is not even broke in yet could it be that? it has about 200 miles on it. Also there is a squeak coming from my timing belt i think.
Status
