How to install MBC on 1jz on stock twins?
Prettyazznouka
75
NYC
I searched for a write up but cant seem to find anything. I thought I saw a diagram once but I cant find that either. I need to turn it up to atleast 15lbs!!!
supramike7m
92 teal-wn turbo
Jan 29, 2006
759
prescott, Arizona
you just need to tee both wastegates together, run them to your bc, and then tee both turbos and run them to the other port on the bc. the rear turbo is somewhat of a pain, not too bad though.
sc250tt
twins @20 psi
Mar 22, 2007
10
florida
Be prepared to get a fcd .I had a mbc on my sc but it spiked wayy to much so i dropped it for a hks evc.
one jay
us
what supramike said, just tee the vacuum lines front the front and rear turbos together. but if you do start hitting boost cut, dont get a fcd, swap out your 1jz map sensor for a jdm 2jz map sensor. much safer
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
... they have been shown to read up to the same PSI(18). Run a MR2 fcd (tunable boost cut) and an AFC.
