how to get camshafts off?
Status
Not open for further replies.
Blackfin
Beach Bum
Jun 16, 2005
205
John's Pass, Florida
No special tools needed. Remove the timing belt. Hold the gear from turning using a screwdriver or something and loosen the bolts. Then pull, or gently pry while alternating sides, the cam gears off.
Make sure that you don't mess up the timing. The timing mark on the existing cams or 0 degree mark on aftermarket cams, should be straight up, while Piston # 1 is all the way up and the crankshaft is also at 0 degrees.
doom26464
Research...research
Saskatoon SK, Canada
try putting a screw driver in there doesn't work......
timing is probaly all ready messed up lol but I will worry about that later when I put everything back together.
SO should I just go ahead and order this tool then to get them off???
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
place flat head though on the bolt on the backing cover get soem els or your self to loose nt he nut remmber shock is what gets shit off some plum it
refeing never get you any ware setp broken nukles and such
that or use a rubber oil filter band to get ti off
trydrew
Suprafied
Nov 4, 2005
1,038
Earth
Look on the cam between the cyl 1 and cyl 2 lobes. There is a spot there were you could put an adjustable wrench and have someone keep them from turning while you unwrench the bolt.
Blackfin
Beach Bum
Jun 16, 2005
205
Well that tool is only meant to hold the cam gear from turning. I never nneded one and wouldn't get unless I used it alot. Maybe try a little breakfree to loosen things up. If all else fails, pull the valve cover and put a wrench on the camshaft itself. The torque on the cam gear bolts is only 36 ft-lb.
Leave the belt on hold the crank pully bolt with a 19mm socket on a breaker bar then undo the Cam bolts.....
(Usually just shocking a ratchet and socket on the cam pully bolts works fine)
Inygknok
Tropical Paradise
Sep 22, 2005
488
Puerto Rico
I got some spare, high grade bolts and put one into one of the holes in the back cover. To "dampen the blow" a bit, I covered the bolt with some napkins I had lying around, and just enough so the cam gear would instantly meet the resistance of the napkins without turning at all. It prevented the bolt from being bent and didn't need any extra hands. Of course, with an impact wrench, this would all be over within 10 seconds or so (10 seconds taking your sweet time).
doom26464
Research...research
Well I do happen to have an impact wrench so that should help
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
Just put a 10mm socket on one of the two bolts behind the gear that hold the rear timing belt cover in place and have at it... the gear's spoke will bind against the socket and you're set.
speed
Gone. Email me.
May 27, 2006
1,045
not here
www.timduganphotography.com
it took 17 replies before this came up?!??!?! Sheesh people! This is by far the easiest way to get 'em off.
Status
