How to fill/flatten side mouldings?
tekdeus
Pronounced Tek-DAY-us
Jan 23, 2006
2,115
Vancouver Canada
www.bitrontech.com
I'm planning to remove the strip and fill the slots on my 89+ side mouldings, like in the pic below.
What's the best flexible and sandable material to use? Since the stock plastic probably won't sand very well, would the material have to be laid overlapping the upper flat part of the moulding?
I've got some generic universal flat 2" side mouldings which I may use, but it probably won't look as good as the stock ones plus they will match the rear center piece.
Idealsupra
Orlando
www.tampabaysupras.com
i could have SWORN he actually is using the 87-88 moldings painted his body color.
not saying you cant fill the 89+ ones though...as ive seen it done... but i thought on THAT application the above was the case. :dunno:
lilazni3uoy
AEM Powered
NoRCaL and SoCaL
^ be more ideal with out all the hard work, using the pre 89 moldings
ma70mkiii
139
ohio
I've done this on another supra before. The easiest way is to use fiberglas filler. Not resin... filler. Its like bondo but fiberglas. Use it as a building block then put a layer of bondo over the fiberglas as a final coat. It will probably take 3-5 good solid coats of fiberglas before it will fill up that ridge enough where it won't show when you paint. If you miss it even by a lil bit it will show. I recommend that you have someone with some autobody background to assist you because if you want it to be perfect.... you have to have a good eye and feel for detail. Shaving mouldings is not easy nor fun so good luck.
cuel
1,536
Baytown, Texas
I've thought about removing the side mouldings, and replacing them with sheet metal, in such a way as I'd only have to feather in the edges with body filler. I'd want to use the stock mounting locations, and epoxy the top and bottom edges. As much filler as it would take to fill over the stock mouldings, I'd worry about it cracking.
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
search around here, i think someone was doing a pretty big build and tacking sheet metal into place. tekdeus maybe?
SilverSupraT
7M '78 Toyota Pickup
Oct 3, 2005
556
Eastern WA
www.geocities.com
Are you talking about filling in the groove in the actual sheet metal or just flattening out the moldings themselves?
If I were doing the moldings I think I would use fiberglass with a flexible resin. The fiberglass filler is nice for somethings but I just doing know how well it would stick to the plastic and I would hate to see it chip off for whatever reason.
If you're trying to shave the moldings completely I would recommend welding, hammer and dolly, then using as little bondo as possible.
Check out my build thread to see the shave job that I did. It was all welded up then just a bit of bondo to help smooth it out. (Link in my sig)
jmanbball
Yellow Jacket
Apr 17, 2006
234
Hittin' the books at Tech
There is some stuff made by 3M called duramix for urethane bumper repair that would probably work well. I used it on the bumper of my brothers car that had been torn in half on the bottom part and it worked really well.
