How to Decarbonize and Engine?
supra90turbo
shaeff is FTMFW!
32
MA, 01440
how to get rid of excess carbon build up inside the engine?
take off the 3000 pipe when engine is hot, with a spray bottle(like windex-type) full of clean water, spray it into the throttle body... dont pour it in there, but mist it. dont use a lot, i cannot stress that enough. sparingly is the key.
*disclaimer*
i do not take any blame in harm caused by this method. it will work if used as described. if too much water is applied, it will hydrolock.
supra90turbo
shaeff is FTMFW!
32
MA, 01440
you ever done a bhg job?
upon removal of head, it is instantly obvious which cylinder had coolant leakage. it looks brand new.
works the same if you have a water injection system. that will keep your combustion chambers brand spankin new.
