As the title states I need someone more competent that me to figure this out...
What I'm doing is calculating the optimum piping diameter for my intercooler pipes matched to the specific turbo I will be buying. The turbo in question is a Stage 5 BOSS, 61 trim with a GTS cover. I asked S.S. the tech questions on this turbo since they do not post them up on their website and here's his response:
Once I figure out what ~75 lbs/min is in CFMs I will use this link: http://not2fast.wryday.com/gasflow/velocity.shtml (supplied by JDub ) to figure out the optimum piping diameter that I can find while getting as close to terminal velocity as possible.
Any help is apreciated, thanks!
Chris
Chris,
Here is a link to ITS and it will show you the map for the GT61. This info was not done with the Boss housing on it and ITS said that our housing is much better that the one used for the maps. ITS also did a flow on the Boss housing and said the flow rate is 75 lbs per minute
The A/R with a stage 5 for the turbine housing is .81
We also are selling a new 4.5 stage turbo from ITS. It has the inducer of the stage 5 and the exducer of the stage 4. What ITS is saying is it has the power of the 5 and spool of the 4. I wave sold almost a dozen of them and they all are happy so far.
Need more help just ask me.
Thanks
Greg Clark
Lipp/SS
Chris
