I need to sell my car (don't want to), but I don't have a realistic price in mind, so I thought it would be a good idea to let the community decide (I would most likely sell to an enthusiast anyway).
Here goes:
mod list:
exterior:
shine front lip
ok 2yr old Barcelona red paint job : it has good spots and bad spots. there are some runs and chips, but that being said from 3-4 ft it looks really good.
interior:
stock in good condition 7/10 (would be higher but has 2 small cracks in dash, shift boot is ripped and trunk carpet is a mess)
engine:
Borg Warner s362 1.10 turbine housing: boost thresh hold 3k rpm, full boost (17 lbs)at 4.7k rpm (was planning on quick spool valve and e85)
drewgo manifold (undivided)
hks standard wastegate dumped to atmosphere (suffers from boost creep)
3 inch split to 2 2.5 inch exhaust
aem truboost
aem wideband
greddy emanage ultimate (street tune)
hks dli
mk4 550's
aeromotive afpr
hks ssqv (using a 5 inch hose clamp to keep it secure because some of the weld pushed into the c clamp area as far as i can tell it doesn't leak)
4 inch core fmic 2.5 inch al piping
heat wrap everywhere
shitty catch can
ss power steering hose
new valve cover, and intake gaskets
exhaust is 3 inch that splits to twin 2.5 just before the diff. All I can say is it sounds amazing!!!!
Mishimoto Radiator with Lincoln mark 8 fan, turns on at 185 and off at 165 (or 175 can't remember)
i may be forgetting a couple of things
everything on the car works including heat and a/c
suspension:
st front sway bar
tokico illumina tems compatible shocks
ground control coilover 650lb front 325 rear
18*8 fr 18*10 r cheap 245 and 265 tires
willwood 13 inch brakes fr porterfield hps rear
needs bushings and an outer tie rod. that being said its an extremely smooth ride on the soft setting of tems.
all that said car pulls really hard to rev limiter at anything above 14 lbs, below that it has decent drive-ability, but needs tuning. I would trust this car to drive anywhere !!!
pics:
dent 1
dent 2
poorly painted trim and trim area
the setup is slightly different, and cleaner
pm me if you want to make a serious offer.
Here goes:
mod list:
exterior:
shine front lip
interior:
engine:
aem truboost
aem wideband
hks dli
mk4 550's
aeromotive afpr
shitty catch can
suspension:
st front sway bar
pics:
dent 1
dent 2
