can someone tell me how many inches of vacuum a properly functioning PVC setup requires? is there a maximum limit to how much you'd want to run? does the vacuum level vary whether the car is in boost or not?
the reason i'm asking is because i'm thinking to use an electric crankcase evacuation pump and i was doing some searching and some super-charged/turbo-charged mustang guys are using this pump for their PCV system:
GM part # 22062562
bracket part # 25534015
it's for a cadillac or something and was specifically designed for PCV applications, and it's only $150 or so from a dealer so i thought it would be worth a try? it generates 8" of vacuum. is this enough for the crankcase on our cars?
the alternatives are either:
- run a stock PCV setup and get oil in the intake
- run a catch can which still will cause ^^^ on some level plus require an assload of hose.
- run a belt-driven pump which would be a pain in the ass to get installed
so what do you guys think? anyone know how much vacuum our cars need???? thanks.
GM part # 22062562
