How much vaccum is your 1jz running?
supraracer49
3rd Gen Life
Nov 20, 2006
333
WNC
My 1jz runs 14 inHg at idle. Just wondering if that is normal for this motor or should it be higher? I checked around for vaccum leaks but couldn't find any. Let me know your guys input on this.
tissimo
Stock is boring :(
Melbourne, FL
with crower 272 small core (264s) i pulled ~ 14-15" at idle (bumped to ~ 900 though). Stock cams ~ 19-20 (same 900 idle)
#1StunnaVic
228
Bronx
i got 19-20 on my 1j but its idling at 1300 rpm i got vacuum leaks but i plugged em up and still is idling kinda high. ill have to check them all again and see if it'll drop down.
supraracer49
3rd Gen Life
Nov 20, 2006
333
WNC
Mines around 700 rpm idle, I live in western north carolina so the elevation is high not sure if that has anything to do with it, my mods are intake, exhaust, bov, and a safc neo. I'm gonna be lookin around for it just wanted to get some input thanks guys!
Tim
regular member
Oct 16, 2006
272
CA
I was at 20 and then it dropped down to about 13-14 after the cams.
Does anyone have a vacuum diagram for the 1jz? After removing my parts to polish, I had one vacuum port with no vacuum lines running to it. I ended up just blocking it off, but I know I had something going to it at one time. Thanks.
#1StunnaVic
228
Bronx
BlackMKIII;901828 said:
Vic: Check your idle speed control. That's too high. :aigo:
My 1J runs about 19 at idle, which is around 700.
how can i check it? the idle speed control is the sensor thats on the intake manifold side all the way in the back by the firewall right? if so then there should be some type of hose or line coming off of it but that hose/ line is not there. can someone post up a picture of it so i can see? i believe this may be the source to my super high idle.
supraracer49
3rd Gen Life
Nov 20, 2006
333
WNC
well I've been looking for it and can't find it anywhere. It has always been around 13.5 in hg. Maybe some jap put cams in mine and i don't know it lol.
supraracer49
3rd Gen Life
Nov 20, 2006
333
WNC
No I haven't had time to go over to my dad's dealership and test it. I've just looked it over for like 5 minutes yesterday.
