How much boost
There's only one way to find out.
All cars are different. Temperatures are different. Take it out on the highway and let her rip tater chip.
I would hope not. 20psi on pump gas will be borderline idiotic I think. I've heard of guys running that much, but I would be afraid of detonation. You'll probably get somewhere around 15psi if I had to guess, but I could be way off. The boost cut is there for a reason, so don't try and fight it. Do the correct mods to your car and you can run a little higher boost. Good luck.
grimreaper
2,180
Dallas
different turbos too! i cant crack 16psi with out my safcII on the sp61 but have heard of others with ct26's nearing 20+Psi on single occasions .
grimreaper
2,180
Dallas
16-17psi on pump unless you have meth is what i would run.
where in tx are you? off topic but are those axis se7ven rims?!
xms
269
tx
I live in san angelo tx and the rims are ray falcon and the car that I have in my sig is my old supie, my new one that Im restorting is will neely old car from from 7m power.
