how much boost can you run on a stock untourqed head gasket, if you tourqe it how much boost can you run, everything is stock minus bov and ct26 with to4e wheel, what do you tourqe the head to anyway?
Hrm... I'm not entirely certain anymore. Once upon a time I was certain it was just ignition cut, but I've heard the ECU has an output to the fuel pump relay, so it could easily cut both at once...bowtiebuba said:lol im sure i will, is the boost cut the fuel cut or are they 2 totallty diffrent things
GrimJack said:Hrm... I'm not entirely certain anymore. Once upon a time I was certain it was just ignition cut, but I've heard the ECU has an output to the fuel pump relay, so it could easily cut both at once...
