How much boost is too much?
ma70t
7mgte-s
Jun 7, 2005
141
va
I wanted to know how many psi can I run if I use forged internals with a compression of 9.0 to 1.
Thanks alot guys!
I was thinking of like 22 to 24 psi on pump gas?
sportinct26
105
cali
ma70t said:
i wanted to know how many psi can i run if i use forge internal with a compression of 9.0 to 1 thanks alot guys i was thinking of like 22 to 24 psi on pump gas
i readlly dont know but it really depends on your mods. i mean like if you have stock ct26 bump it higher than about 14 your running hot air. on the other hand my t78 is "slow" at 14 and when i turned it up to 18 its like a new dam car lol.
drjonez
the motor city
www.4cefed.com
boost pressure is irrelevant. 22 psi on a CT26 is NOT 22 psi on a T78. larger turbos flow more air for a given boost pressure. select a power goal, then select a turbo to get you there.....don't select a boost pressure.
To get all Nerdy and taking it as a stock 7MGTE at 24 psi boost and stock Compression ratio I get the effective compression ratio is 18.77:1 and you'd need at a minimum 122 octane fuel to run it.
Math is a wonderful thing. Sometimes I wish I was smarter instead of so damn good looking.....................:biglaugh:
grygst76
8
Ludlow, MA
I would lower the compression a tad bit more before running that much boost IMO. Still a noob to turbos, but engine knowledge is key.
drjonez
the motor city
www.4cefed.com
NERD!
effective CR is fun to play with, but in reality it can be a bit different.....heck, my (STOCK) engine has survived 30 psi....
sportinct26
105
cali
wait how did you get that? care to explain...
antman
632
TN
you could sell your sole!
