How Many Daily Drivers?
suprabad
Coitus Non Circum
Jul 12, 2005
1,796
I am really curious how many of you drive your Supras on a daily (and I mean everyday) basis?
Also, I'd like to know how many people have only the one car (Supra) and must depend on it totally? How modded is it?
I hear alot of people say that Supra's aren't reliable daily transportation and I disagree. I know cause I only have the Supra and it takes me wherever I gotta go and I have a lot of performance upgrades. Mine is reliable as a stone even with mods :biglaugh:
e90suprat
Mechanically challenged
May 8, 2005
110
Douglasville, GA
I used my 88t as a dd for almost 9 years and it never let me down. I now have a 90t, but I only use it fun, Atlanta traffic sucks ass and it would probably kill the supra.
mkiii222
Troy, MI
Mine has been my only car for just over a year now. I even delivered pizza in it for a while(6 months, but it let me meet the cars 2nd owner and find out that I'm the 4th, original owner was a doctor who got every option, and the 3rd owner is the one that abused it).
I've put 22k on it since the BHG it had when I bought it.
So far it's only needed a new battery(it was a 5 yo battery, replaced with Optima red), new tires(almost time again, Fuzion ZRi, much nicer than expected, but then they are made by Bridgestone), and new hoses(accordian, turbo->IC, and several misc others + clamps, many many clamps). Mainly maintenance type stuff.
Not really modded yet, still working on the minor stuff, and she gets me to work and around town with very little trouble(only got stranded once, and I would have made it to the shop if I didn't back into the grass turning around after an almost overheat).
wingman
sucka got blammed!
Sep 11, 2005
427
Phoenix, AZ
i'm slowly learning that the car has a mind of it's own....If you treat it good, it'll treat you good. if you treat it bad, it'll treat you bad. If you say your sorry and make up it'll run like a champ, but if you ignore it you'll have hell on wheels.
i don't know if that applies to the non-dd's, but I know it applies to me. Having an N/A helps a bit too...
martyn&tara
supra addicts
Jun 6, 2005
77
Somerset. England
Hi my we have a supra each which we use as our daily drivers, we have a further 12 supras which we are restoring and some are show spec and are kept tucked up, martyn does the engines and i do the interiors being a trimmer. they are a hobby obsession and wouldnt dream of drivin any thing else.
aye mate
Hiatus over.
Maryland
My Supra is my first and only car. Mods are in my profile. It has been down for extended periods of time but that was usually because I did something stupid. Its been a great DD, I can't imagine driving anything else for as long as I have driven the Supra.
Supra Blues
Virgin Booster
Supramania
Daily driver here for the most part.
If its raining, I leave it in the garage. The only reason it is a daily driver is because it is much more fun to drive then my 91 Ford Explorer with 190,000 miles and a leaky sunroof.
Mr.PFloyd
I am the Super Devil
Jun 22, 2005
3,964
Mississauga, Ontario
it's my DD. Im 17 still in high school with the fastest car in my parking lot (that includes teachers too hahah). You just gotta keep posting on here and figure out whats wrong and if peeps can help you. If something's wrong. double check everything. if it happens again, then you sure as hell gotta be prepared for the worst. And this is my only car up until the winter. when winter hits, its gonna be bus every morning :(. hmm maybe if my bro gets a car it'll be a winter one :D
7M-GTE
ROCK$T@R
Apr 2, 2005
535
KC
my 89 is my daily driver... and also my only car... it's a bitch to rely on... I've put maybe 3500 miles on it since jan 31st... so it's not very reliable... but I'm hopin that it is when all is said and done...
mkIIIman089
Ohio
I only have one car, and like Cryo, I'm 17 and in HS. Supra has been perfectly reliable for me, I keep up extremely well with maintenance and watch my Greddy guages pretty well.
Mods:
Apexi intake
Cooleeze full IC pipe kit
NGK plug wires
NGK Iridiums 1 heat range colder
JBLMK3 EGR block off plates
Stainless brake lines
Stainless clutch line
HTS vacuum hoses
PWR radiator
Blitz rad cap
JBLMK3 turbo elbow
Random Tech downpipe
3" test pipe custom length for nur spec
Blitz NUR Spec
Sparco race wheel
GReddy water temp, oil pressure, fuel pressure guages in center consol
Blitz turbo timer
Spec Al flywheel
Spec stage 2 clutch
Al 1 piece driveshaft
4.30 LSD
whopwood
56
Madison, WI
One car, driven daily for 5+ years. Has never left me on the side of the road. Although, I have "had" to call in to work a day or two for unexpected repairs ;)
Intake:
- Alamo 2.5" hard pipes
- 57 trim ct-26 (no exhaust clip)
- Alamo IC
- SSQV to atmosphere + recirculating Bosch
- 3" hotwire AFM
- MAF-T
Exhaust:
- Suprasport turbo elbow
- RT 3" DP
- RT 3" cat
- 3" Tanabe Hyper Medalion cat-back
Fuel:
- MKIV pump
- RC 550cc injectors
- Aeromotive 13109 AFPR (3.25 kg/cc base)
Electric:
- Apexi S-AFC
- Apexi AVC-R
Instruments:
- Tech Edge v2.0 Wideband O2
- Greddy electric fuel pressure
Suspension:
- Tokico Illumina IIs
- Borbet Type H, 16", 5 spokes
- SupraSport strut bars
- ST anti-sway bars
Misc:
- metal HG
- RPS clutch plate
- Aluminum 1 piece driveshaft
- G-stop SS brake lines
- one washer on the wastegate actuator to make the AVC-R happy :)
gixxer750
2jzget comingsoon!
Mississippi
mine is a daily driver, its pretty modded and I run it hard on the weekends. I also have a 2005 nissan titan crew cab, but I drive the supra unless I need to haul something. (Truck only has 2500 miles on it, had it for 4 months) The supra has never left me stranded, not once.
MA70Supra88
Boostless
Boerne, TX
My Supra is my only car and I drive it every single day. It has never once stranded me in the more than 4 years that I've owned. It is a stock '88 N/A.
empera
Authorized Vendor
Philly.
right now its a DD, but try no to drive it much because of gas and because of rain and such. Hopefully i will have a Subaru SVX soon...as a DD
7M-GTE
ROCK$T@R
Apr 2, 2005
535
KC
I wish I could say the same as all of you that have never had problems with your supras but mine has left me on the side of the road to many times to count... but I still love the car and out of the year that I've owne my 89 I've only been able to put 3500 miles on it... and the same went with my 87... but I did put a few more miles on the 87...
Loki
The Future is Unwritten
Prince George, B.C.
My car was my DD, I never had a problem with it. Then I blew up the turbo, and right up until it spun a bearing I had no problems with it. It wasn't too modded, just a lil bit.
mazzer
438
st.louis,mo
91 t .daily driver minor mods. bought it with 84k on the ticker2 yrs ago and it now has 99k on it.only left me on the side of the road once and thats due to the BHG(imagine that) when it blew a coolant hose.other than that its been a GREAT car.the short mod list includes,new o.e.m. head gasket w/ arp's @ 74 lb/ft,full port matched head to manifolds,full race grind on valves,polished stock exhaust manif, 3" DP,shimmed WG to 9 PSI, cone filt adapt,type-s BOV and other non-performance mods..im convinced ill NEVER NOT own a supra for the rest of my life be it mkiii or the infamous/ illustrious mkiv. sorry to hear about the troublesome ones.
