how many amps on cranking?
suprra_girl
7M POWAH! ;)
Auckland, New Zealand
www.supra.co.nz
hey ya'll
i'm trying to find out how much amperage the fusebox & starter motor draw on cranking
so here's the low down
relocated battery to boot, installed splitter box with 100amp fuses, ran cable to front of car, want to install another splitter box but this one only holds 60amp fuses which i'm intending to run the starter and the fuse box power wires
power cable is 4gauge to front splitter box then out to 2x 8gauge for starter & fuse box
when i crank the engine will i blow the 60amp fuses? and will the wiring be suitable?
Thanks :D
Dirgle
Conjurer of Boost
Pauma Valley, CA
1. Yeah, you will blow the fuse. At 11.5 volts our starters can pull as much as 121+ Amps.
2. I would also get a larger set of wires. 8-gauge is a bit small for a starter. And 4-gauge is a bit small for a run all the way back to the boot.
You could get away with 4-gauge run all the way, and not have any problems. But personally I would go with 2-gauge in place of the 4-gauge and 4-gauge in place of the 8-gauge, it is a bit over kill, but that’s just me.
Hope this helps. ;)
Dirgle
Conjurer of Boost
Pauma Valley, CA
I make my own jumper cables, and I use that welding cable. Makes jump starting a dead car easy. You hook them up and the dead car turns over like it had a fresh battery.
I got tired of using cheap travel jump cables and having to wait 5 min before the dead car had enough juice to turn over.
I used to run the - cable from the battery to the chassis then a short cable at the front across to the motor and ended up running 2x 500+ CCA batteries in my Z to overcome the V drop!
In the Supra with a single optima yellow there is very minimal V drop running the welding cables all the way up to the front! :)
If I could buy some decent aligator clamps I'd make a set of jumpers that's a great idea! (my bought ones in both cars are crap)
IHI-RHC7
"The Boss"
Oregon
yeah, I suggest getting 2 "Ought" welding cable and going that route.
4 gauge cannot handle a 7m starter too well. I ran 4 4guages to keep the wires from heating up.
IHI-RHC7
"The Boss"
Oregon
No problem, we ran it just like you suggested in my dad's car a few years back and it works great!
malloynx
NC
funny you ask this. i just did this on a VAT the other day. starter pulls about 130amps on start-up
5uprahboy
343
Auckland
Wow - I had no idea that the starter pulls that many amps. I have a 1G which is the 2litre supra motor - I'm assuming that altho smaller, it will still pull over 100amp?
xarewhyayen
276 whp - 324 tq @ 13psi
Oct 3, 2005
959
Philly
Did VAT test in class today... 128 amps @ 10.8 volts while cranking. Also did hydrometer test on battery and found out all 6 cells are below acceptable numbers for specific gravity. Time for a new battery!!
xarewhyayen
Oct 3, 2005
959
Philly
haha i know... Its okay, if it shall breaketh, Thou shalt upgradeth. Therefore I'm now considering optima+relocation to hatch via Welding cables.
supra90turbo
shaeff is FTMFW!
32
MA, 01440
A smart choice indeed Ryan.
It seems I picked the right time to rebuild my car.
So many great ideas have been pointed out in the recent past that I would have not done and been pissed about after the fact.
Now just to remember them all.... :D
suprra_girl
7M POWAH! ;)
www.supra.co.nz
yea i was gonna use a 150 or 200amp fuse
one like this
guess i'll go 150 ;)
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
that whould a be waffer fuse the 150 is easy to find any local audio shop
remmber all you are protecting is the wire not the starter
