How does a sprung clutch work?
born2drv
1,199
Burbank, CA
I just got my HPF full-face feramic clutch in today, and I've always wondered, how exactly do the springs work as far as smoothing out the transmission? What forces do they absorb and how? I can't see how the springs make contact with anything moving to expand and contract? It looks like there are just 6 springs wedged in there....
Thanks!
xarewhyayen
276 whp - 324 tq @ 13psi
Oct 3, 2005
959
Philly
the clutch is made of 2 pieces and the springs are set between the hub and the clutch bodies. When you slam it ( drop the clutch, or even ease into it), the spring dampens the torsional force. I know it looks like its just one piece, but if you give it enuff force you'd see the springs compress some
born2drv
1,199
Burbank, CA
thats what i thought too... but between all the 6 springs, are 6 pins or whatever that hold the hub and the plate together.... so i thought that kept it rigid making the springs pointless....
so i guess these pins also bend during high loads? i guess it's only supposed to be a very very small deflection?
lintlars
ROOTS RADICALS
Ft.St.John BC
make sure you dont use an aluminum Flywheel they WILL weld together there has been two of us on here in the last month that they did not tell that to. We both welded together on the first burn out we did.
SupraB
Need 4 speed mods!
Jul 24, 2006
71
Spokane WA
whoah.... what was that about aluminum flywheels??? Im doing a clutch job very soon and I was plannin on puttin in a lightwheight flywheel.... I dont wanna do that??? Or is it just on certain clutches?
Thanks you might have saved me alot of time and money.
Brendan
Clifton
Scottsdale, Az
Aluminum flywheels use steel inserts. No different that an all steel flywheel.
lintlars
ROOTS RADICALS
Ft.St.John BC
Very different actually using the feramic (fullface)clutch creates much more heat since it has a much higher melting point which the AL FW cannot dissipate fast enough so the two get welded together the stock FW is all steel so disspates the heat there have been two of us in the past month with the same setup in which this has happened to Ive used the AL FW with other clutches but Im refering the Feramic in this post. I should have specified in my post.
MDCmotorsports
Indy 500
www.MDCmotorsports.com
:3d_frown: :nuts:
Son - Put the crack down. Please.
Aluminum not only heats up faster than steel, it dissapates heat twice as quick.
As for welding clutches together - you've put something together wrong.
lintlars
ROOTS RADICALS
Ft.St.John BC
Wow why did two of us with the same setup have the exact same outcome HPF told me after the fact that this clutch does not work well with an AL FW if you put the two metals together the small disk cannot dissipate the heat fast enough Im well aware the aluminum dissipates heat faster, nothing was put together wrong.
Clifton
Scottsdale, Az
Being that there are thousands of aluminum flywheels in use on many different makes and models that work fine I would have to say that the problem is
1. Disk material(HPF)
2. Operator error (excessive slipping of clutch).
