how do I remove a driver seat with motor out of car
ForcedTorque
Join the 92 Owners Group
Jul 11, 2005
6,099
I need some ideas on how to get the back 2 bolts out of the drivers seat with it slid all the way back, and there is no power to the car at all. I have my motor out of the car, and both battery cables came with it. Is there a way to hook up the cables, so I can get power to the car?
I have a pigtail with extended wiring that fits the plug closest to the console. I have removed them from parts cars before with it, but they were pre 89 seats. Is there a difference? I can't remember if I ever had another plug to fit in the other place. The one plug and a battery don't seem to be doing it like it has before. The seat definitely worked before I removed the motor.
Also, I have removed the dash. Will the plugs that I disconnected have any effect on the seat? I have these seats sold, and need to get them shipped. And, it looks like the next thing sold will be the targa top. I gotta get the seat out of there very soon!
I did do a search, and I didn't see any easy help. I did see this, but it does absolutely nothing to me. Any help figuring that out (if it will work with no battery) will help as well.
http://cygnusx1.net/Supra/Library/TEWD/MK3/manual.aspx?S=Main&P=98
tbcmorris
SM Expert Thread Derailer
Mar 14, 2007
1,820
PRUVEN PERFORMANCE MILFORD CT
this is how i would do it...get a battery and 2 wires, remove the switch for the front and back movement..jumper the swith with you pos and negitive from you baterry. if it doent move the desired direction sitch the wires....this will switch the motors polarity moving it the other way
ForcedTorque
Jul 11, 2005
6,099
To help others in a search.......What I did was, I connected the two battery cables back to a battery, making sure to connect the auxiliary wire to each to each cable. I also made sure that the opposite ends of the cables were not touching anything at all. This powered the car, and I simply just used the switch on the seat.
