How do I make sure my air bag won't blow my face off while replacing the heater core?
CajunKenny
PULL MY FINGER. PLEASE!
Nov 15, 2007
3,255
Washington
Hi Guys!
I have a 91 and want to start on my heater core replacement sometime this week; but, want to make sure I don't damage or cause the air bag to blow in the process. :aigo:
Is disconnecting the battery sufficient?
Any recommendations or pointers on this job?
Sincerely,
Your fellow MKIII owner that wants to keep his face. :biglaugh:
92TealSupra
Supramania's Parts Man
Sep 2, 2008
1,584
Great Lakes State
I have taken the airbag off my '90 and '91 what I do is pull the fuse, and then disconnect the battery for 30 minutes. then put it back and no problems, also just take the battery out of the car just to make it it doesn't re_connect
:icon_bigg
CajunKenny
Nov 15, 2007
3,255
Washington
Good point on the battery. Take it out! :)
Is the heater core accessible from below at all or can you only get to it from the top by pulling the dash out?
CajunKenny
Nov 15, 2007
3,255
Washington
Oh, I wasn't questioning you. I was just hoping to get any and ALL pointers possible. Especially regarding the airbag.
Do you agree that disconnecting the battery WILL prevent the airbag from going off?
92TealSupra
Sep 2, 2008
1,584
Great Lakes State
See the main reason for pulling the battery out is so the airbag can't get power, I say leave it for 30 minutes because cars have capacitors that will trickle power to memory items in the car. If you take the fuse and that you will be perfect, and everything will be safe for you, and anyone else around you.
CajunKenny
Nov 15, 2007
3,255
Washington
Thanks guys! I wasn't second guessing anyone. I just want to be safe. After all, I like my face where it is! :D
Well, I did as instructed and have the glove box out, radio, ebc, gauge cluster, etc...
Does the steering wheel have to come off or is there a way to drop the column down further. I think I see some bolts/nuts that may allow it to drop a bit more; but, not sure.
