How do I know if I'm at TDC
crrider80
Too soon Jr.
Jun 3, 2006
341
NYC
Hi guys, in order to get your #1 piston at TDC you have the match up the notch on the crank pulley with which one of the marks on the timing belt cover? I have it currently pointed at "0" and the cam notches pointed at the notches on the plate behind the gears. also, how would i go about in setting the ignition timing? THanks in advance!
-Steve
crrider80
Too soon Jr.
Jun 3, 2006
341
NYC
supra90turbo said:
Sorry, but THANKS a million!
basically,
"Originally Posted by lagged
align the CRANK pointing to ZERO degrees, the CAM GEARS using the MIDDLE dowl, pointing UP to the notches in the cam plate.
install the timing belt with this orientation.
when inserting the CPS, the hole on the housing must be pointing towards the front of the car, with the crank at ZERO insert the cps.
when setting the timing, set it to 10 degrees."
Got it.
-Steve
