how do i change my front quarterpanel blinker lights?
xarewhyayen
276 whp - 324 tq @ 13psi
Oct 3, 2005
959
Philly
the one under the headlight? or the marker light on the side trim piece?
if you mean the turn signal on the front of the car, theres a screw on the side of the signal.. just remove that and it should come out
JMDigital
Authorized Vendor
Jun 2, 2006
976
Tampa, Florida
If you mean the blinker that waraps arround the side a little. There is a screw on the right side in the front and a hidden screw on the inside behind the radiator catch can. Gotta take that out to get to it. on the drivers side. Look at the one on the passenger side to get an idea where it is. That one is easy to get out.
JDM 1JZ
I hate Tires
Aug 31, 2005
301
Cherry Hill, New Jersey
dont forget about the hidden one behind the grill piece:naughty: thats why 99% of them out there are broken haha, loosen the visible screw and pull, then that little hidden ear snaps, well thats how it is on the 89+ front end atleast
if it is an 89+ behind the grill and under the nose cone theres a tiny phillips head screw, unscrew slide grill out, un-screw the hidden screw and the one on the side that xarewhyayen had noted
Silvasoup
143
Florida
Wait if you just want to change the front turn signal bulbs all you have to do is raise your headlights so you can gain access to the back of the turn signal and the socket just twists out. Why would you try and unscew the front? That is what the question sounds like to me. He just wants to replace burnt out turn signal bulbs. Right?:confused:
PimpiNJ253
Supraless
Sep 15, 2006
183
Kent, Washington
i want to replace the signal that has the trim surrounding it. not the front ones but will be useful in the future for reference:icon_razz I messed with it for about 1 min then wanted to ask before gettin out the screwdriver and breakin sumthin.
oh and i have a 88
ChadMKIII
Yup, Thats The G/F
Jul 14, 2006
369
Bay Area, Ca
Wow, way old thread. Its all in the instruction manual explicitly how to.
Do you want the signals up front or the side marker lights? I'll try to tomorrow. The side markers are RIDICULOUSLY easy. pretty much jut slide and pull.
